plt3DIChart GetShadowVisibility
Returns the shadow’s visibility state.
plt3DIChart_handle GetShadowVisibility
Tcl Query
Returns the enabled state of the chart’s shadow.
None.
Gets a handle to a pltIVector interface for the specified curve.
Returns the chart’s highlight state.
Gets the number of points on the chart.
Returns the chart’s shadow color index.
Gets the shadow plane of the chart.
Gets the symbol style of the chart.
Gets the chart’s visibility state.
Sets the chart’s highlight state.
Sets the chart’s shadow color index.
Sets the shadow plane of the chart.
Sets the auto shadow visibility state.
Sets the symbol style of the chart.
Sets the auto chart visibility state.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
