plt3DIChart SetHighlighted
Sets the chart’s highlight state.
plt3DIChart_handle SetHighlighted state
Tcl Modify
- True
- Highlighted.
- False
- Not highlighted.
Success (0) or an error code.
Gets a handle to a pltIVector interface for the specified curve.
Returns the chart’s highlight state.
Gets the number of points on the chart.
Returns the chart’s shadow color index.
Gets the shadow plane of the chart.
Returns the shadow’s visibility state.
Gets the symbol style of the chart.
Gets the chart’s visibility state.
Sets the chart’s shadow color index.
Sets the shadow plane of the chart.
Sets the auto shadow visibility state.
Sets the symbol style of the chart.
Sets the auto chart visibility state.
ON THIS PAGE
Tcl Modify
ON THIS PAGE
