txtIReportManager SetDefaultBackgroundColor
Sets the default background color.
txtIReportManager_handle SetDefaultBackgroundColor color
Tcl Modify
This command sets the default text background color in TextView. You must open a new TextViewsession to notice the changes in the default settings.
- color
- The number representing the index (position) of the color (from the color palette) that you want to set as the default background color.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr TextEditor;
mgr SetDefaultBackgroundColor 16;
Keywords
Tcl
Text Edit
Modify
