txtIReportManager SetDefaultTextColor
Sets the default text color.
txtIReportManager_handle SetDefaultTextColor color
Tcl Modify
This command sets the default text color in TextView. You must open a new TextView session to notice the changes to the default setting.
color
A number representing the index (position) of a color (from the color palette) that you want to set as the default text color.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr TextEditor;
mgr SetDefaultTextColor 16;
Keywords
Tcl
TextView
Modify
