OS-V: 0310 Deep Simply-Supported Beam Periodic Forced Vibration Response
Test 5P OptiStruct is used to investigate the Peak Displacement in the y-direction and extreme fiber bending stress at the mid-span node.
図 1. FE Model with Boundary Conditions and Loadcases
Model Files
Benchmark Model
Timoshenko beam and Engineer’s beam elements are used to model the simply-supported beam which consists of 10 elements. The displacements in x, y, and z direction, as well as the rotation in x direction are fixed at the end A. In addition, the displacements in y and z direction are constrained at end B. A steady-state periodic forced vibration F = F0 (sin ωt-sin 3ωt) is induced in the y-direction. (F0 = 106 N/m uniformly distributed, ω = 2ωf, f = 20 Hz). For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1 = 5.36 and α2 = 7.46×10-5 are given.
- Material Properties
- Value
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Frequency Response Summary
- f*
- Closed form solution
| Peak Displacement (mm) | Peak Stress (N/mm2) | |
| Reference Solution | 0.951 | 17.10 |
| HOE: | ||
| Direct Solution | 0.982 | 17.367 |
| Normalized | 0.968431772 | 0.984626015 |
| Modal Solution | 0.982 | 17.369 |
| Normalized | 0.968431772 | 0.984512637 |
| LOE: | ||
| Direct Solution | 1 | 19.6 |
| Normalized | 0.951 | 0.87244898 |
| Modal Solution | 1 | 0.951 |
| Normalized | 19.6 | 0.87244898 |
Reference
NAFEMS R0016 - Selected Benchmarks for Forced Vibration, J Maguire, D J, Dawswell, L Gould 1989
