OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
OptiStruct uses the S-N approach for calculating the fatigue life. The S-N approach is suitable for high cycle fatigue, where the
material is subject to cyclical stresses that are predominantly within the elastic range. Structures under such stress
ranges should typically survive more than 1000 cycles.
The E-N (Strain - Life) method should be chosen to predict the fatigue life when plastic strain occurs under the given
cyclic loading. S-N (Stress - Life) method is not suitable for low-cycle fatigue where plastic strain plays a central
role for fatigue behavior.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
OS-HM-T: 6010 Fatigue Process Manager (FPM) using S-N (Stress - Life) Method
fatigue life. The S-N approach is suitable for high cycle fatigue, where the material is subject
stress ranges should typically survive more than 1000 cycles.
Before you begin, copy the file(s) used in this tutorial to your
working directory.
The S-N approach is based on elastic cyclic loading, inferring that the S-N curve should be
confined to numbers greater than 1000 cycles. This ensures that no significant plasticity is
occurring. This is commonly referred to as high-cycle fatigue.
Figure 1. Low Cycle and High Cycle Regions on the S-N Curve
Since S-N theory deals with uniaxial stress, the stress components need to be resolved into
one combined value for each calculation point, at each time step, and then used as
equivalent nominal stress applied on the S-N curve (Figure 2).
Figure 2. Two segment S-N Curve
In OptiStruct various stress combination types are available,
with the default being "Absolute maximum principle stress". In general "Absolute maximum
principle stress" is recommended for brittle materials, while "Signed von Mises stress" is
recommended for ductile material. The sign on the signed parameters is taken from the sign
of the Maximum Absolute Principal value.
In this tutorial, you will be able to evaluate fatigue life with the S-N method through
process manager step by step.
A control arm loaded by brake force and vertical force is used, as shown in Figure 3. Two load time histories acquired for 2545 seconds with 1 HZ, shown in
Figure 4 and Figure 5, are applied. The material of the control arm is aluminum, whose S-N curve
is shown in Figure 6. Because a crack always initiates from the surface, a skin meshed with
shell elements is designed to cover the solid elements, which can improve the accuracy of
calculation as well.
Figure 3. Model of Control Arm for Fatigue Analysis
Figure 4. Load Time History for Vertical Force
Figure 5. Load Time History for Braking Force
Figure 6. S-N Curve of Aluminum
Launch Altair HyperWorks/HyperMesh and
Process Manager
Launch Altair HyperWorks from the launch menu.
A New Session dialog is displayed.
Select the HyperMesh radio button and set Profile
to OptiStruct and click the
Create Session button.
From the Templates ribbon, select the
Analyze menu and select Fatigue
PM.
For New Session Name, enter <my_session_name>.
For Working Folder, select your working folder.
Click Create.
This creates a new file to save the instance of the currently loaded
fatigue process template.
Import the Model
Make sure the task Import File is selected in the
Fatigue Analysis tree.
For the Model file type, select OptiStruct.
Click the Open model file icon .
A Select File browser window opens.
Select the ctrlarm.fem file you saved to
your working directory and click Open.
Click Import.
This loads the control arm model. It includes a whole definition of two
static subcases, elements sets, and material static properties,
etc.
Click Apply.
This guides you to the next task Fatigue Subcase of the Fatigue Analysis
tree.
Figure 7. Import a Finite Element Model file
Set Up the Model
Create a Fatigue Subcase
Make sure the task Fatigue Subcase is selected in the Fatigue Analysis
tree.
In the Create new fatigue subcase field, enter fatsub_fpmtut.
Click Create.
For the Select existing fatigue subcase field, select the newly created fatigue
subcase fatsub_fpmtut.
fatsub_fpmtut is selected as the active fatigue
subcase. Definitions in the following processes (analysis parameters, fatigue
elements and properties, loading sequences, etc.) will be for this
subcase.
Optionally, you can choose to create all fatigue solver cards (such as
FATPARM, FATDEF,
FATEVNT, PFAT etc. that are created in
subsequent steps) in a separate include file. For this, you should select the
check box Create include file for fatigue solver cards
(optional).
Click Apply.
This saves the current definitions and guides you to the next task
Analysis Parameters of the Fatigue Analysis tree.
Figure 8. Create and Select Active Fatigue Subcase to Process
Apply Fatigue Analysis Parameters
Make sure the task Analysis Parameters is selected in the Fatigue Analysis
tree.
Select the following options:
Analysis type
S-N
Stress combination method
Signed von Mises
FEA model unit
MPA
Mean stress correction
GERBER
Rainflow type
STRESS
Enter the following values:
Certainty of survival
0.5
Gate
0.0
Click Apply.
Elements and Materials of the Fatigue Analysis tree. For details, consult the
Altair HyperWorks2023 help.
Figure 9. Fatigue Analysis Parameters Definition
Add Fatigue Elements and Materials
Make sure the task Elements and Materials is selected in the Fatigue Analysis
tree.
Click Add Material.
A Material Data window opens.
Figure 10. Material Data Definition
For Material name, select Aluminum.
Make sure Stress unit is set to MPA.
For Ultimate tensile strength (UTS), enter 600.
Click SN Curve Material Properties.
An SN Curve Material Properties dialog opens.
Figure 11.
For Input method of defining S-N curve, select Estimate From
UTS.
Click the Show SN curve definition icon .
An SN method description window introducing how to generate the SN
material parameter opens.
Click Close.
For Material type, select Aluminum Alloys and click
Estimate.
All the data for SN curve definition are automatically
estimated.
Click OK.
Click Plot SN Curve at the bottom of the window to show
the SN curve.
Figure 12.
Close the SN Curve plot window.
Click Add Property.
A Property Data dialog opens.
Figure 13.
For Property Type, select Property - PSHELL.
For Property name, select shell.
This is the skin coating the solid control arm.
Click Create to create PFAT property.
For LAYER, select TOP.
For FINISH, select NONE.
For TREATMENT, select NONE.
Leave the field after KF (Fatigue strength reduction factor) set at
1.0.
Click Close to save the definition of the SN data for
the selected property.
Click Close in the Property Data dialog to save the
fatigue definition.
Load-Time History of the Fatigue Analysis tree.
Figure 14. Elements and Material Definition
Apply Load-Time History
Make sure the task Load-Time History is selected in the Fatigue Analysis tree.
Click Add by File.
A Load Time History window opens.
For Load-time history name, enter LTH1.
For Load-time history type, select CSV.
Click the Open load-time file icon .
An Open file browser window opens.
Browse for load1.csv.
Click Open > Import.
Click Save to write the new load-time history into
HyperMesh database.
Create another load-time history LTH2 by importing the
file load2.csv.
Figure 15. Import Load-Time History
Click Plot L-T to show the load-time history.
Close the Load Time History window.
Click Apply.
Loading Sequences of the Fatigue Analysis tree.
Figure 16. Load-Time History Definition
Load Sequences
In this step, one event
consisting of two load time history is created; in other words, the linear superposition
of the stress caused by the two load time history is requested during analysis. Using
this event, one load sequence is constructed.
Make sure the task Loading Sequences is selected in the Fatigue Analysis tree.
Click Add.
A Load Mapping window
opens.
For Channels, select LTH1 and
LTH2.
For Subcase, select SUBCASE1 and
SUBCASE2.
Activate the radio button Auto and leave the event
creation method set to default Single Event.
Click + to create a single event with two subcases and
two channels.
Set Scale to 3.0, as shown below.
Figure 17. Load Mapping to associate load-time history with static
subcase
Click Save to close the window and create the fatique
event using selected subcases and channels.
Figure 18. Loading Sequences Definition
Submit the Job
Make sure the task Submit Analysis is selected in the Fatigue Analysis
tree.
Click the Save .fem file icon .
A Save As browser window opens.
Set the directory in which to save the file, and for File name, enter ctrlarm_fpmtut.fem.
Click Save to close the window.
Click Save to save the OptiStruct model file.
For Run Option, select analysis.
Click Submit.
This launches OptiStruct2023 to run the fatigue analysis. If the job is
successful, the new results files should be in the directory from which
ctrlarm_fpmtut.fem was
selected.
The default files written to the directory are:
ctrlarm_fpmtut.0.3.fat
An ASCII format file which
contains fatigue results of each fatigue subcase in
iteration step.
ctrlarm_fpmtut.h3d
Hyper 3D binary results
file, with both static analysis results and fatigue
analysis results.
ctrlarm_fpmtut.out
OptiStruct output file containing
specific information on the file set up, the set up of
your fatigue problem, compute time information, etc.
Review this file for warnings and errors.
ctrlarm_fpmtut.stat
Summary of analysis
process, providing CPU information for each step during
analysis process.
Note: The filename.#.fat is created for each
fatigue subcase at the first and last iterations only if a fatigue
optimization is performed.
Figure 19. Submit Fatigue Analysis
Figure 20.
Post-process the Analysis
Make sure the task Post-processing is selected in the Fatigue Analysis
tree.
When fatigue analysis has completed successfully after the previous submit, it
will automatically go into this task.
For Fatigue subcase, make sure Select Subcase is
selected.
For Result Type and Data Component, select the required data you want to
contour from the drop-down menu.
Click Load H3D Results (HV).
This launches HyperView and loads the
ctrlarm_fpmtut.h3d results file. It applies the
result contour for selected result type and component. You can use HyperView for more detailed results.
