Arbitrary Lagrangian-Eulerian (ALE) and Computational Fluid Dynamics (CFD)
- Transient Analysis
- Laminar and turbulent flow ( model, LES Smagorinsky)
- Compressible and semi-incompressible flow
- Conductive heat transfer
- Fluid/structure coupling
- Multi-material
- Classical fluid flow analysis
- Internal flows
- Aerodynamics
- Free surface
- Open channel with obstacles
- High speed tooling
- Fluid/structure interaction
- Valves
- Exhaust noise source prediction
- Laser welding
- Nuclear accidents
- Defense
