*DEFINE_TABLE_2D
LS-DYNA Input Interface KeywordThis keyword defines a 2D table.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_TABLE_2D | |||||||
| table_ID | SCA | OFFA | |||||
| A1 | Curve_ID1 | ||||||
| A2 | Curve_ID2 | ||||||
| An | Curve_ID3 | ||||||
Definition
| table_ID | Curve
identifier. (Integer) |
| SCA | Scale factor for the value
An. Default = 1 (Real) |
| OFFA | Offset for the value
An. Default = 0 (Real) |
| An | Value that corresponds to the
following nth curve identifier. (Real) |
| Curve_IDn | Defined curve
identifier(s). (Integer) |
- This keyword maps to /TABLE/1.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
