/GAUGE/POINT
Block Format Keyword Defines gauges. Gauge can be used to save the pressure, density and specific energy histories at a fixed position.
The /TH/GAUGE card must be defined to output histories in the time history file.
| /GAUGE/POINT/gauge_ID/unit_ID | |||||||||
| gauge_title | |||||||||
| X | Y | Z | |||||||
Definition
| gauge_ID | Gauge identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit
| gauge_title | Gauge global title. (Character, maximum 100 characters) |
| X | X coordinate for
gauge. (Real) |
| Y | Y coordinate for
gauge. (Real) |
| Z | Z coordinate for
gauge. (Real) |
- A gauge can be defined by position using coordinates X, Y, Z, then the gauge is fixed in space and time.
- Position is updated if transformation is applied on sub model (//SUBMODEL).
- In the time history file, the gauge will have the following name, gauge_title.
- Gauges can be used for ALE and for Finite Volume Method.
