/GRNOD/BOX
Block Format Keyword Describes a node group inside the referenced box.
| /GRNOD/BOX/grnd_ID/unit_ID | |||||||||
| grnod_title | |||||||||
| box_ID | |||||||||
Definition
| grnd_ID | Node group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grnd_title | Node group
| box_ID | Box identifier, which
is defined in Boxes (Integer, maximum 10 digits) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- If type is BOX, all nodes inside the box are selected.
