/GRNOD/GRSPRI
Block Format Keyword Describes the node groups which are selected from spring groups.
| /GRNOD/GRSPRI/grnd_ID/unit_ID | |||||||||
| grnd_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grnd_ID | Node group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grnd_title | Node group
| item_ID1, item_ID2,..., item_IDn | List of spring group
identifiers (Integer) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- If item_ID is a positive GRSPRI id number, all nodes associated with the referenced spring group are added to the node group.
- If item_ID is a negative GRSPRI id number, the nodes associated with the referenced spring group are deleted from the node group.
