/TH/ACCEL
Block Format Keyword Describes the time history for accelerometers.
/TH/ACCEL/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
Obj_ID1 Obj_ID2 Obj_ID3 Obj_ID4 Obj_ID5 Obj_ID6 Obj_ID7 Obj_ID8 Obj_ID9 Obj_ID10
Definition
thgroup_ID TH group identifier
(Integer, maximum 10 digits)
thgroup_name TH group name
var_ID1, ...n Variables saved for TH (see table below)
(Character, maximum 8 characters)
Obj_ID1, ...n Identifiers of the objects to be saved
(Integer)
TH Output Keyword & Variables
Keyword Object Saved Variables
ACCEL Accelerometer AX, AY, AZ, WX, WY, WZ
Available Variables - Part 2
Keyword Variable Group Saved TH Variables
ACCEL DEF AX, AY, AZ
  W WX, WY, WZ
Output for Accelerometer
  • AX: acceleration in direction X
  • AY: acceleration in direction Y
  • AZ: acceleration in direction Z
  • WX: integral of acceleration in direction X
  • WY: integral of acceleration in direction Y
  • WZ: integral of acceleration in direction Z
    Let γ g = the nodal acceleration vector expressed in the global skew system, γ s the nodal acceleration vector projected onto the moving skew.
    Let ν g = the nodal velocity vector expressed in the global skew system, ν s the nodal velocity vector projected onto the moving skew.
    Let R ( t ) = the orientation matrix of the skew at time t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDaaaa@36CF@ , so that: (1)
    γ s = R ( t ) ⋅ γ g
    (2)
    v s = R ( t ) ⋅ v g
    Derivating ν s versus time leads to:(3)
    d v s d t = d R d t v g + R d v g d t = d R d t v g + R γ g = d R d t v g + γ s
    This shows that derivating the nodal velocity projected onto the moving skew, ν s does not give an equivalent result to the nodal acceleration projected onto the moving skew, γ s .
    The vector WX, WY, and WZ available for output in the accelerometer is:(4)
    w = ∫ 0 t γ s ( u ) d u
    Derivating this output will give a value of γ s nodal acceleration projected onto the moving skew, the integration-derivation acting as another filter other than the 4-pole Butterworth, which is used in the accelerometer and computes the filtered accelerations AX, AY, and AZ.
  1. Available outputs are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
