/TH/SUBS
Block Format Keyword Describes the time history for subsets.
| /TH/SUBS/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
Definition
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| SUBS | Subsets | IE, KE, XMOM, YMOM, ZMOM, MASS,
HE TURBKE, XCG, YCG, ZCG, XXMOM, YYMOM, ZZMOM IXX, IYY, IZZ, IXY, IYZ, IZX, RIE, KERB, RKERB, RKE |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| SUBS | DEF | IE, KE, XMOM, YMOM, ZMOM, MASS, HE |
Output for Subset in the Global Skew System
- IE: internal energy
- KE: kinetic energy
- XMOM: translational X momentum in the global reference frame
- YMOM: translational Y momentum in the global reference frame
- ZMOM: translational Z momentum in the global reference frame
- MASS: mass of the part
- HE: hourglass energy
- TURBKE: turbulence kinetic energy (only for fluid applications)
- XCG: center of gravity coordinates
- YCG: center of gravity coordinates
- ZCG: center of gravity coordinates
- XXMOM: rotational X momentum in the global reference frame
- YYMOM: rotational Y momentum in the global reference frame
- ZZMOM: rotational Z momentum in the global reference frame
- IXX: inertia matrix
- IYY: inertia matrix
- IZZ: inertia matrix
- IXY: inertia matrix
- IYZ: inertia matrix
- IZX: inertia matrix
- RIE: shear internal energy
- KERB: transitional rigid body kinetic energy
- RKERB: rotational rigid body kinetic energy
- RKE: rotational kinetic energy
- A part (resp. a subset) can not be in several time history groups. In this case, the only variables output in time history are the variables declared in the last option which refers to the part (resp. subset).
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- In 2D axisymmetrical computation, energies are given per radian.
- Output for subset or part (for /TH/SH3N or /TH/SHEL only):
HE: global hourglass energy with visco-energy added for numerical stabilization if QBAT and QEPH shell formulations (Ishell =12, 24) are used (refer to /PROP/TYPE1 (SHELL)).
