Altair Inspire User Guide
2023
  1. Home
  2. Reference
    View the glossary, frequently asked questions, and errors and alerts.
  3. Errors and Alerts
    Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest solutions when problems are found.
  4. Motion Errors and Alerts
    View suggested solutions for resolving Motion errors.
  5. Run Termination Errors
    This section contains information about how to resolve run termination errors in Inspire Motion.
  • What's New
  • Get Started
  • Tutorials
  • Parametric Modeling
  • Implicit Modeling
  • Structures
  • Motion
  • Fluids
  • Design Explorer
  • Manufacture
  • Print 3D
  • Rendering
  • Inspire Python API
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2023
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire? Learn the basics here.
  • Tutorials
    Start using Inspire with our interactive tutorials.
    Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
  • Implicit Modeling
    Create implicit models with primitives, lattices, point clouds, fields, offsetting, Booleans, inverting, smoothing, morphing, and filleting.
  • Structures
    Set up your model and run a structural analysis or optimization.
  • Motion
    Set up and run a motion analysis, plot the results, and export the results.
  • Fluids
    Prepare and run a computational fluid dynamics simulation.
  • Design Explorer
    Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
  • Manufacture
    Set up and run a basic porosity or thinning analysis.
  • Print 3D
    Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
  • Rendering
    Adjust the materials and environment of objects in the scene to create a photorealistic image.
    Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
  • Reference
    • Frequently Asked Questions
      Got questions? We have answers!
    • Troubleshooting
      Need help troubleshooting a problem? Check out our troubleshooting topics.
    • Errors and Alerts
      • Inspire Errors and Alerts
        There are a number of problems that can prevent analysis or optimization from running successfully. The most common reasons for failed runs are improperly defined load cases.
      • Motion Errors and Alerts
        • Modeling Errors and Alerts
          The section contains information about how to resolve modeling errors in Inspire Motion.
        • Run Termination Errors
          • Motor/Actuator Is Ignored During Statics Analysis
          • Profile Span Is Too Small
          • Profile Duration Is Too Short
          • Allowable Deformation in Joint Has Been Exceeded
          • Deformation Sensors Disabled
          • All Sensors Disabled
          • Coil Spring/Damper Endpoints Too Close or Crossed
          • Coil Spring Free Length Is Negative
          • Part Has Incorrect Inertia Properties
          • Analysis Error 40000
          • Statics Analysis Is Not Converging for Your Model
          • Transient Analysis Is Not Converging for Your Model
          • Abnormal Analysis Error
          • Possible Mechanism Lockup Conditions Encountered
          • Analysis Error 70002
          • Analysis Error 71000
          • Analysis Error 71002
          • Assembly Analysis Is Not Converging for Your Model
          • Support Type Not Allowed for Motion Load Extraction
          • Motion Analysis Results Not Found
          • No Parts to Analyze
          • Part Reference Frame Is Not Global
          • No Design Space
          • Syntax Error Encountered in Model
          • Dynamic Friction Coefficient Exceeds Static Coefficient
          • Stiction Transition Velocity Exceeds Friction Transition Velocity
          • Invalid Collision Type
          • Motion Contact Analysis Error
          • Error Detected While Processing Geometry
          • Motion Contact Force Results Not Found
          • Total Number of Contact Forces Is Very Large
          • Force Vectors Are Unavailable
          • Ambiguous Initial Conditions
          • Initial Velocity Defined on Massless Parts
          • Failure Creating Flexible Body for Part
          • Unable To Find Attachment Node
          • Unsupported Solver
          • All Parts Are Rigid
          • No Eigenanalysis
        • Information and Alerts
          This section contains information and question alerts in Inspire Motion.
    • Glossary
      View a list of glossary terms and definitions.
    Learn keyboard shortcuts and mouse controls for common operations.
2023
  1. Home
  2. Reference
  • What's New
  • Get Started
  • Tutorials
  • Implicit Modeling
  • Structures
  • Motion
  • Fluids
  • Design Explorer
  • Manufacture
  • Print 3D
  • Rendering
  • Reference
Index
  • No Design Space
  • No Eigenanalysis
© 2024 Altair Engineering, Inc. All Rights Reserved.
