Use the Center of Gravity Constraint (COG) tool to apply, reposition, and set upper and lower bounds for a center
of gravity constraint. COG constraints are used to limit the position of the center of gravity while running a topology
optimization.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
