Generate multiple sketches to create a parametric bracket with recessed areas using the Offset, Push/Pull, and Boolean
tools, and using a construction line as a reference. You will also assign dimensions and create variables.
Learn how to use constraints and construction geometry to create more sophisticated sketches. In this example, you'll
build a tapering arm for a clamp around a reference centerline, paramaterizing the sketch in terms of the construction
lines.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
