Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Extract curves resulting from the intersection of the sketch plane with selected
parts or surfaces.
Create Intersection Curves
On the Sketch ribbon, select the
Intersect tool.
On the toolbar, select Parts to choose parts to
intersect with the sketch plane, or select Surfaces to
choose surfaces to intersect with the sketch plane.
Select part(s) or surface(s) that intersect with the sketch plane to create
intersection curves.
The intersection curves appear as a dotted red line or curve, and can interact
with your new sketch.
Right-click and mouse through the check mark to exit, or double-right-click.
Note: When a sketch plane is defined on the face of a part (or an
impression on the face of a part), the intersection curves are generated
automatically. You can disable this option in the Preferences under Sketching > Show intersection curves on sketch plane creation.
