Diode
This item tracks the voltage and signal lines in the circuit, calculates the voltage value of each net, and checks whether the all diode connected to the net is within the allowable voltage range.
- Component: Select Diode component group to be checked.
- Pin: Assign pin
information of diode. User can assign pin number using Pin Number or Pin
Property which contain pin number information.
Figure 2. - Power Net: Select power net group to which Diode components are connected.
- Ground Net: Select ground net group to which Diode components are connected.
- Voh: Set the output high voltage (Voh) of driver pin. You can set this by entering the value directly or select the property name which contain voh value.
- Vol: Set the output low voltage (Vol) of driver pin. You can set this by entering the value directly or select the property name which contain vol value.
- Reverse Voltage
Check: Set the allowable reverse voltage of this diode. You can set this by
entering the allowable value directly or select the property name which
contain allowable reverse voltage value. You can also assign tolerance of
this check.
Figure 3. - Zener Voltage Check:
Set the allowable Zener voltage value of this component. You can set this by
contain allowable Zener voltage value. You can also assign tolerance of this
check.
Figure 4.
Stress Test Option
Set whether passive components are considered short or open when navigating signals and power lines.
