Photo Coupler
This item tracks the voltage and signal lines in the circuit, calculates the voltage value of each net, and checks whether the all photo coupler connected to the net is within the allowable voltage range.
- Component: Select Photo Coupler component group to be checked.
- Pin: Assign
pin information of Photo Coupler. You can assign pin number using Pin Number
or Pin Property which contain pin number information.
Figure 2. - Net: Select net group to which Photo Coupler components are connected.
- Power Net: Select power net group to which Photo Coupler components are connected.
- GND Net: Select ground net group to which Photo Coupler components are connected.
- Voh: Set the output high voltage (Voh) of driver pin. You can set this by entering the value directly or select the property name which contain voh value.
- Vol: Set the output low voltage (Vol) of driver pin. You can set this by entering the value directly or select the property name which contain vol value.
- Diode
Reverse Voltage Check: Set the allowable reverse voltage of diode of this
component. You can set this by entering the allowable value directly or
select the property name which contain allowable reverse voltage value. User
can also assign tolerance of this check.
Figure 3. - TR Vce
Check: Set the allowable Vce voltage of transistor of this component. You
can set this by entering the allowable value directly or select the property
name which contain allowable Vce value. You can also assign tolerance of
this check.
Figure 4.
Stress Test Option
Set whether passive components are considered short or open when navigating signals and power lines.
