Buckling Linear
You can create and solve linear buckling problems in structural analysis.
To solve linear buckling, first apply a reference level of loading, , to the structure.
Then, perform linear static analysis to obtain the stresses needed to form the geometric stiffness matrix, , corresponding to . Calculate buckling loads by solving an eigenvalue problem. Not all eigenvalues are required; only a small number of the lowest eigenvalues are normally calculated for buckling analysis.
