2023
Create an analysis for your project.
Fatigue analysis is intended for predicting life of structures under cyclic loading.
View new features for SimSolid 2023.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Evaluate your design in real-time using SimSolid dynamics analysis.
Thermal analysis predicts how thermal effects propagate through the model. Steady state and thermal transient analyses are supported.
Background information on Fatigue analysis in SimSolid.
Import a loadcase-channel map file to import all the channels defined in the file and create appropriate events.
Import channels which define load amplitude changes in time.
Review channels in a group.
Create an event consisting of channels and loadcases.
Import a file to automatically create load case sequences.
Create a sequence with load cases for the fatigue analysis.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
ON THIS PAGE
