The seam weld fatigue implemented in SimSolid is based on linearization of stress in the conjunction with Volvo method and following that it predicts fatigue
damage and life. Linearized stress decomposes a through-thickness elastic stress field into equivalent membrane and
bending.
Background information on Fatigue analysis in SimSolid.
Fatigue Assessment Methods
In SimSolid, uniaxial and multiaxial fatigue analysis using SN (stress-life) and EN (strain-life) approach is supported.
Stress-life (SN) Approach
The stress-life method works well in predicting fatigue life when the stress level in the structure falls mostly in the elastic range.
Strain-life (EN) Approach
The EN Approach uses plastic-elastic strain results to perform strain-life analysis.
Seam Weld Fatigue
The seam weld fatigue implemented in SimSolid is based on linearization of stress in the conjunction with Volvo method and following that it predicts fatigue damage and life. Linearized stress decomposes a through-thickness elastic stress field into equivalent membrane and bending.
