Material Properties
Material properties define the structure and thermal characteristics of each part in the assembly.
Material properties must be defined based on the problem physics. Mechanical properties must be defined for structural analysis. Young’s modulus, density and coefficient of thermal expansion are mandatory fields. Thermal analysis requires definitions for thermal properties and density.
Additionally, material yield strength is used to calculate factors of safety. For fatigue analysis, fatigue properties must be specified by estimating from UTS or input of Stress-Life or Strain-Life curve parameters.
