Mouse Controls
Mouse controls for model view manipulation and component selection in SimSolid
Default Settings
| Mouse Control | Description |
| 3D-Rotate | Click + drag Left mouse button |
| Zoom | Mouse scroll wheel Note: When zooming in/out, this changes the
center of rotation/orbit.
| 2D-Pan | Click + drag Right mouse button |
Modeling Window Controls
| Select individual entity | Left mouse button |
| Select multiple entities | Control + Left mouse button |
| Display entity context menu | Right mouse button |
| Display global context menu | Right-click in empty area of modeling window |
Change Mouse Control Settings
Modify mouse controls from the default settings.
- In the menu bar, click .
- In the dialog, use the drop-down menu to select desired mouse settings.
- Optional: Select the Set as default check box to save settings for future sessions.
- Click OK.
