The Linux version of SimSolid works without any
user-interface and is meant to run jobs on HPC clusters.
Note: To access the SimSolid user-interface, use the Windows
version. An SSP is required to submit jobs on Linux clusters.
Use the installer to install SimSolid on any Linux
machine.
Once the installation is successful, you can use the command line below to run
SimSolid jobs.
<installation folder>/altair/scripts/SimSolid -s <Path to .js file>/<filename>.js -p <path to SSP file>/<SSP filename> -l <path to log file>/log.txt
Commands
to use in the
.js file to execute
SimSolid jobs in batch:
// open project
Project.open({ file: '%1%.ssp'});
//Set number of logical cores
Project.setOptions({ numOfCoresToUse: 24 });
// initialize solutions
Project.initializeSolutions();
// solve all analyses
Project.solveAllAnalyses();
// save project
Project.save({ file: '%1%_solved.ssp'});
The above script
performs a series of actions namely - opens an SSP file, initializes the
solution, runs all the analysis, and saves the SSP by appending _solved to the
original file name. It is also set to run the jobs using 24 cores.
