Bolt and Nut Tightening Background Information
Bolt forces can be applied to bolt and nut geometries in SimSolid.
Bolts and Nuts
- Blind bolts
- Bolts with nuts
- Nuts on threaded rods
- Nuts on a generic post or handle
Relationship Between Torque M and Axial Force F
M is the maximum moment realized at the end of the tightening and it is equilibrated by moment from friction forces in contact between nut and the structure.
R0 and R1 are inner and outer radii of the contact spot. Friction distributed force will be where f is a friction coefficient.
Axial Force
This implies: .
