Remote Displacement
Apply displacements to faces and/or spots that are statistically equivalent to a load applied on a single point.
Remote displacement is only available for structural linear and non-linear analysis types.
View new features for SimSolid 2023.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
A comparison chart showing the available boundary conditions for each analysis type.
Enforce zero translational displacements in all directions on faces, edges, vertexes, and/or spots.
Enforce zero displacement in normal to the surface direction on faces and areal spots.
Allow free rotation about the centerline of cylindrical faces, and constrain movement in radial and axial directions.
Set an elastic foundation at selected faces.
Constrain displacement of faces, edges, vertices, or spots in Modal analysis.
Apply shortening or change of length for cables/rods.
Apply positive pressure towards a face or negative pressure outwards from a face.
Apply uniform loads and/or displacements to faces, edges, vertices, or spots.
Simulate the force of gravity as it affects your model.
Apply a uniformly distributed translational inertia load over the volumes of the parts in an assembly.
Apply a uniformly distributed rotational inertia load over the volumes of the parts in an assembly.
Simulate deformations and stresses in cases where you have an unconstrained structure to which an active load is suddenly applied.
Apply distributed loads (tractions) to faces and/or spots that are statistically equivalent to a load applied on a single point.
Simulate deformations and stresses induced by the temperature changes in your model.
Apply a varying pressure load to full or partial face(s) of revolution.
Define pressure exerted by a fluid at equilibrium.
Apply distributed mass across selected faces.
Available for blind bolts (bolt without a nut), bolt with nut/bolt on threaded rod, nut on generic post or handle.
Apply volumetric expansion/shrinkage coefficient over seam welds or other parts in the assembly.
In thermal analysis, limit temperature on the selected faces, edges, vertices, or spots to a prescribed value.
Allows importing temperature at various points of the model for various load steps.
In thermal analysis, define a convective heat exchange condition on faces and spots.
In thermal analysis, apply uniformly distributed heat loads to faces and spots.
In thermal analysis, simulate internal heat generation and internal heat absorption in volumes.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
ON THIS PAGE
ON THIS PAGE
