Import Remote Loads from CSV
Apply/create load cases with remote Forces/Moments from an external comma separated values (CSV) file.
Imported Remote Load CSV File Format
CSV file format for importing remote loads.
CSV file format fields
- X, Y and Z – Numeric values. Spatial location of the remote load.
- Fx, Fy and Fz – Numeric values. Force component values in X, Y and Z directions.
- Mx, My and Mz – Numeric values. Moment component values in X, Y and Z directions.
- Load case – (optional) String value. Only required if multiple load cases are present.
- X1, Y1 and Z1 – (optional) Numeric values. Spatial location of a point on the 1st face to be mapped. Only required if mapping to specific faces.
- T1 – (optional) Yes/No. No entry is treated as ‘No’. Enables tangency option to add faces tangent to the face mapped using X1, Y1, Z1.
- X2, Y2 and Z2 – (optional) Numeric values. Spatial location of a point on the 2nd to be mapped. Only required if mapping to specific faces.
- T2 – (optional) Yes/No. No entry is treated as ‘No’. Enables tangency option to add faces tangent to the face mapped using X2, Y2, Z2.
- Coordinate System – (optional). Coordinate system name. Name of the
coordinate system to resolve the loads. Loads will be resolved in global
coordinate system if the column fields are empty or if the column is
missing.Note: Spatial location coordinates will still be in the Global coordinate system.
Example CSV file
X,Y,Z,Fx,Fy,Fz,Mx,My,Mz, X1,Y1,Z1,T1,X2,Y2,Z2,T2 ,Load case,Coordinate System
50,50,50,100,0,0,0,0,0,10,20,20,Yes,70,70,70,No,load_1,LCA1
50,10,50,0,100,0,0,0,0,,,,,,,,,load_2,LCA2
