Altair HyperStudy 2023.1 Release Notes
New Features
Quantification of complex relationships between inputs and outputs
Global variance-based sensitivity method, based on Total Sobol Indices.
Integration of physicsAI models
physicsAI models can now be deployed inside HyperStudy.
Alternative graphical user interface
As well as the classic interface, a new ribbon style interface is now available.
Enhancements
3D visualization of CAE models and results
Visual post-processing of simulation models and results is now supported via Media Sources.
Auto-selecting best fit model for vector predictions
FAST algorithm has been extended to support vector fits.
Optimization with vector responses
Optimization goals can be defined directly on Data Sources.
Terminating processes in different ways
The stop command in the Evaluate step now supports options on how to terminate a process.
Flexibility in finding files to purge
Purge tool now supports wildcard-based search and selecting files through the browser.
Auto-handling of hanging subprocesses
A timeout option has been added in Evaluation Parameters to terminate zombie child processes.
Resolved Issues
  • Numerical discrepancies in Tutorial HS-1610.
  • Undo action did not work for removed models.
Announcements
  • Availability of Xopt will be deprecated in version 2024.0.
