Altair Squeak and Rattle Director 2023.1 Release Notes
New Features
Support for Acceleration Load
Sine sweep load creation now supports Acceleration as a load type. This option also creates the associated PARAM card required for acceleration load.
Constraints in All Direction
In the Dynamic Event tool, you can use the Constrains in all direction checkbox to create SPC in all directions along with the loading direction in enforced excitations.
Enhancements
Risk Assessment Tab
If you switch to another ribbon after loading, the Results tool will clear the contours automatically.
LCS Rotation Tab
Automatic increase in LCS size when in the Manage E-Points tool.
Post Results Plots
The summary page will have Z Rel displacement bar plots instead of Magnitude plots, full analysis results will have Z Rel displacement contours, and line level plots will show Z relative displacement with gap and tolerance.
Resolved Issues
  • Results visualization in combined load cases has been resolved for dynamic and static load cases. Combined loading supports only rattle lines. Previously, squeak lines results were plotted.
