Dye Regions
Used for fluid motion tracking.
- Dye regions can only be spherical in shape.
 - If a particle passes through multiple dye regions, it will adopt the color of the last dye region through which it passed.
Commands
dyeRegions
    dyeRegion
        dyeregion_clr           1
        dyeregion_cntr          "0.0 0.1 0.2"
        dyeregion_rad           0.1
        dyeregion_radodx        2.5
        dyeregion_tstart        0.0
        dyeregion_tend          1.0
| Command | Contents | SI Unit Example |
| dyeregion_clr | Color assigned to the dye region | |
| dyeregion_cntr | Center coordinates of the dye region sphere | [m] |
| dyeregion_rad | Radius of the dye region sphere | [m] |
| dyeregion_radodx | Radius of the dye region sphere as a function of
                                     Tip: For example, when
                                    specified 3.0, this implies
Note: If both
                                        dyeregion_rad and
                                        dyeregion_radodx are present, the latter
                                    takes precedence.
| dyeregion_tstart | Start time of dye injection | [s] |
| dyeregion_tend | End time of dye injection | [s] |
