Impose Regions
Define any number of regions to alter/prescribe velocity, acceleration, porous media or temperature.
There are two categories to define: geometric shape and effect type.
Available geometric shapes:
- PARALLELEPIPED
 - CYLINDER (with or without hemispherical caps)
Available effect types:
- Velocity (corresponding command suffix:
*vel) - Acceleration (corresponding command suffix:
*acc) - Porous media (corresponding command suffix:
*porous) - Temperature (corresponding command suffix:
*temp)
Any combination of shapes and effects is permitted, making for total of eight possible scenarios (or 12 if you count cylinders with hemispherical caps as a separate shape). The impose region type name is composed by specifying the geometric shape and adding the effect suffix in capital letters, for example: PARALLELEPIPEDVEL, PARALLELEPIPEDPOROUS, CYLINDERACC, or CYLINDERTEMP.
The fluid velocity region imposes a velocity on all fluid particles which are within the prescribed region. The easiest analogy is a pump mechanism (momentum source), except that there are no moving parts involved. The acceleration region imposes a defined acceleration on all the particles which are within the defined region. It also can be thought of as a momentum source region, except that by defining the acceleration instead of hard-setting the velocity of the particles, the region is likely to behave more stably. Porous media definition follows the well known Darcy-Forchheimer model and allows for definition of volume averaged isotropic or non-isotropic porous media. Finally, the temperature region assigns a temperature to all fluid or wall particles (optional) which are within the prescribed region, and is essentially a heat source/sink.
In addition to shape and effect types, there are specific commands which are applicable to a specific subset of desired shape-effect combinations. For example, as already mentioned, cylinder shape has a possibility to include hemispherical caps at the ends of the cylinder, such that if you specify the height of the cylinder as zero, you would end up with a spherical shape. More obviously, parameters which define the geometry are different between PARALLELEPIPED and CYLINDER impose regions.
There is also a possibility to SET a magnitude of a desired field value inside the impose region or use the ADD the command to add the specified value to any instantaneous field value the particle might have inside the impose region.
One other variable which allows flexibility is the LOOSE/STRICT option, which allows for either hard (strict) imposing of the specified value, or soft (loose) imposing of the specified value. If we take an example of specifying velocity in X direction - STRICT definition will impose exactly the vector which the user provides, with Y and Z components being equal to zero. If we use the LOOSE option, the code will impose the X direction velocity, but will allow the solver to naturally accommodate (calculate) Y and Z velocity components.
The final option available is to define inertial (INERT) or body (BODY) frame of reference for velocity effect regions. If INERT is selected, the velocity/acceleration definition in the region assumes that the general (default) simulation coordinate system is used, which is the common case. This means that whatever velocity/acceleration is specified, it will be used as such. In case the user specifies the velocity and enables BODY frame of reference, the resulting velocity/acceleration vector in the region will be specified vector plus the velocity/acceleration of the body. This can be useful in specific scenarios.
Figure 1. Commands supported for each effect type
Commands
The regions are defined through a separate parameter section called imposeRegions.
When specifying the geometry of the shape type commands in the imposeRegions, a specific nomenclature is followed. Each command begins with the shape definition, followed by a suffix which defines the effect, followed by an underscore and key suffix (which is effectively unique to each command). For example:
parallelepiped<effect>_A_vec or cylinder<effect>_axismore specifically resulting in parallelepipedvel_A_vec or cylinderporous_axis.
Additionally, when defining time series (varying parameters in time), additional suffixes are used for file, offset and latch commands. These suffixes are _tvs_ (time velocity series), _tas_ (time acceleration series) and _tts_ (time temperature series).
On the other hand, effect definitions are universal, such that once the impose region shape parameters are defined (using appropriate suffixes), you can add effect parameters.
We are emphasizing these definition principles in order to concisely (modularly) present the set of commands, instead of listing all eight (optionally 12) possible versions of the impose region definitions.
imposeRegions
	imposeRegion
		;NOTE:
		;<shape>  = {parallelepiped, cylinder}
		;<effect> = {vel, acc, porous, temp}
		;<time_series> = {_tvs_, _tas_, _tts_}
		; UNIVERSAL PARAMETERS
		imposeRegion_type                       PARALLELEPIPEDTEMP
		t_start                                 0.0
		t_damping                               0.1
		t_end                                   20.0
		imposeregion_motphs                     1
		<shape><effect>_mode                    SET
		<shape><effect>_constraint              LOOSE
		<shape><effect>_frame                   BODY
		<shape><effect><time_series>file        time-dependent-series.txt
		<shape><effect><time_series>offset      0.1
		<shape><effect><time_series>latch       false
		; PARALLELEPIPED PARAMETERS
		parallelepiped<effect>_corner           "0.0 0.0 0.0"
		parallelepiped<effect>_A_vec            "1.0 0.0 0.0"
		parallelepiped<effect>_A_len            2
		parallelepiped<effect>_B_vec            "0.0 1.0 1.0"
		parallelepiped<effect>_B_len            4
		parallelepiped<effect>_C_vec            "1.0 0.0 1.0"
		parallelepiped<effect>_C_len            3
		; CYLINDER PARAMETERS
		cylinder<effect>_axis                   "0.2 0.2 0.4"
		cylinder<effect>_cntr                   "0.2 0.2 0.4"
		cylinder<effect>_hght                   0.8
		cylinder<effect>_rad                    1.0
		cylinder<effect>_caps                   false
		; VELOCITY PARAMETERS
		<shape>vel_unv                          "1.0 2.0 0.0"
		<shape>vel_vel                          12.0
		use_prtl_reuni                          false
		; ACCELERATION PARAMETERS
		<shape>acc_acc                          100
		<shape>acc_unv                          "0.0 0.0 1.0"
		; TEMPERATURE PARAMETERS
		<shape>temp_temp                        150.0
		<shape>temp_fluidonly                   false
		; POROUS MEDIA PARAMETERS
		porous_principal_ax_x                   "1.0 0.0 0.0"
		porous_principal_ax_y                   "0.0 1.0 0.0"
		porous_principal_ax_z                   "0.0 0.0 1.0"
		porous_inert                            "1000.0 10.0 1000.0"
		porous_inert_offdiag                    "1000.0 10.0 1000.0"
		porous_visc                             "100.0  100.0 10.0"
		porous_visc_offdiag                     "100.0  100.0 10.0"
| Command | Contents | SI Unit Example |
| imposeRegion_type | Type of impose region. The key word is a composite of two
                                    keywords defining shape and effect associated with the impose
                                        region. Shape keywords
 Effect keywords
 Tip: Any combination of the shape and
                                            effect keywords is permitted. For example, a
                                            parallelepiped porous media would be type:
                                                PARALLELEPIPEDPOROUS, or a
                                            cylindrical velocity region would be:
                                                CYLINDERVEL.
| t_start / t_end | Common parameters for all imposed regions, indicating
                                    beginning and end of time at which the region is
                                        active. Default = 0.0 Note: t_end must be greater than or equal
                                        to t_start.
| t_damping | During this period, the prescribed velocity, body force or
                                    temperature will reach it prescribed value (analogous to the
                                        t_damping in the Motions section). Note: The command makes
                                        no physical sense for porous media, so in case the user
                                        specifies it in the porous impose region - the command will
                                        be ignored.
Default = 0.0 Note: t_damping will be
                                        renamed to t_ramping in the future, as it
                                        describes better the effect it has in the
                                    simulation.
| imposeregion_motphs | Impose regions are capable of following a MOVINGWALL phase with a predefined motion. This command specified the MOVINGWALL phase ID, which the region will follow. | |
| <shape><effect>_mode | Defines the mode of the impose region, are the specified
                                    values added or set inside the impose region. Options
 Note: This command is not applicable to porous regions
                                            (makes no physical sense).
Default = SET  |
| <shape><effect>_constraint | Defines the constraint of the impose region, are the
                                    specified values strictly or loosely imposed in the region. Option
                                            and temperature regions (makes no physical
                                            sense).
Default = LOOSE  |
| <shape><effect>_frame | Defines the relevant reference system when specifying a
                                    velocity impose region. Note: This command is only applicable to
                                        the velocity impose regions.
Option
 Default = INERT  |
| <shape><effect>_tts_file | Name of the text file containing time-variable pairs (column
                                    format, no header, space delimiter), thus defining variable
                                    behavior of the desired field inside the impose region (Time
                                    Table Series – TTS). Tip: For
                                        example, velocity TTS file format is:
time u v w. |
| <shape><effect>_tts_offset | Time offset value in case that the TTS
                                    file starts at a time different from zero, for example begin
                                    using TTS at t = 10 s. Default = 0.0  |
| <shape><effect>_tts_latch | Boolean command for keeping the last value of the
                                        TTS file throughout the
                                        simulation. Tip: For example,
                                            TTS file defines only a ramp-up
                                        curve for the imposed region, from t = 0 to t = 5 s and
                                        velocity in X direction from u = 0 to u = 3 m/s, while the
                                        total simulation time is t_final = 10 s. If latch is set to
                                        true – for t > 5 s, velocity will be set constant at 3 m/s
                                        (last value in the TTS file). If latch
                                        is set to false, the velocity for t > 5 s will be set to 0
                                        m/s.
Default = false  |
Parallelepiped Specific Commands
Figure 2. Schematic View of a Generic Parallelepiped
| parallelepiped<effect>_corner | Coordinates of the defining the origin corner of the parallelepiped. This is a vector variable of the format: "X Y Z". | [m] |
| parallelepiped<effect>_A_vec | Three components of the vector A, which is defining one side
                                    of the parallelepiped.  Note: This is a vector variable of the
                                        format: "X Y Z".
| parallelepiped<effect>_A_len | Length of the side A (magnitude of the vector A). Note: This
                                        value is a scalar.
                                [m] |
| parallelepiped<effect>_B_vec | Three components of the vector B, which is defining one side
                                        format: "X Y Z".
| parallelepiped<effect>_B_len | Length of the side B (magnitude of the vector B).  Note: This
                                        value is a scalar.
                                [m] |
| parallelepiped<effect>_C_vec | Three components of the vector C, which is defining one side
                                        format: "X Y Z".
| parallelepiped<effect>_C_len | Length of the side C (magnitude of the vector C).  Note: This
                                        value is a scalar.
                                [m] |
Cylinder Specific Commands
| cylinder<effect>_axis | This vector defines the main axis of the cylinder.  Note: This
| cylinder<effect>_cntr | These are the coordinates of the center of the cylinder base
                                    where axis is located.  Note: This is a vector variable of the
                                        format: "X Y Z".
                                [m] |
| cylinder<effect>_hght | Defines the height of the cylinder in the direction of axis.
                                         Note: This is a scalar value (length).
                                [m] |
| cylinder<effect>_rad | Cylinder radius. | [m] |
| cylinder<effect>_caps | Boolean switch which controls adding of hemispherical caps on
                                    the cylinder bases (resulting in a pill-shape geometry). The
                                    caps are added to both sides of the cylinder. Default = false  |
Velocity Region Specific Commands
| <shape>vel_unv | This vector defines the direction of the velocity. Note: If
                                        time series file is specified, this command is ignored. This
| <shape>vel_vel | Defines the magnitude of the velocity. Note: If time series
                                        file is specified, this command is ignored. This is a scalar
                                        value.
                                [m/s] |
| use_prtl_reuni | Toggles the use of transport velocity or artificial particle
                                    displacement (APD) inside the porous region. Attention: It is considered to be an advanced
                                        parameter.
Option
 Default = false  |
Acceleration Region Specific Commands
| <shape>acc_unv | This vector defines the direction of the
                                        acceleration. Note: If time series file is specified, this
                                        command is ignored. This is a vector variable of the format:
                                        "X Y Z".
| <shape>acc_acc | Defines the magnitude of the acceleration. Note: If time
                                        series file is specified, this command is ignored. This is a
                                        scalar value.
                                [m/s2] |
Temperature Region Specific Commands
| <shape>temp_fluidonly | Switch which allows to prescribe the temperature to only
                                    fluids, or alternatively to all FLUID, MOVINGWALL or WALL
                                        particles. Default = false  |
| <shape>temp_temp | Temperature which will be assigned to all the particles which enter the temperature region. | [K] |
Porous Region Specific Commands
It is generally assumed (default) that the principal axes of the porous region align with the base simulation X, Y, and Z coordinates (inertial reference frame). If that is not the case, a separate coordinate system can be defined and the values defining porosity will be considered in that new coordinate system. The commands which define the custom principal axes of the porous region are:
| porous_principal_ax_x | Defines the X principal axis of the custom coordinate
                                    system. Note: The format of the command is a 3-component vector
                                    value of the form "X Y Z".
| porous_principal_ax_y | Defines the Y principal axis of the custom coordinate
| porous_principal_ax_z | Defines the Z principal axis of the custom coordinate
| There are four parameters which define the volume averaged porosity of the region: | ||
| porous_inert | Defines the diagonal inertial coefficients in the
                                Darcy-Forchheimer porosity model. If the values of this vector are
                                all set to 0.0 and all the components of
                                    porous_visc are set to non-zero, then the
                                used porosity model effectively becomes the Darcy model/equation. Note:
                            [1/m] |
| porous_inert_offdiag | Defines the off-diagonal inertial coefficients in the
                                Darcy-Forchheimer porosity model. Note:
                            [1/m] |
| porous_visc | Defines the diagonal inertial component coefficient in the
                            [1/m2] |
| porous_visc_offdiag | Defines the off-diagonal inertial component coefficient in the
                            [1/m2] |
