Frame Suite
This section expands on frame suite set up sliding frame for water wading applications.
The frame suite was developed in order to address the use case of water wading, specifically the case where a vehicle is entering a body of water under a specified angle and moving through an arbitrarily long channel. The basic idea behind the frame suite is to have a simple set of parameters that define the setup, for example, define the road, water depth and domain boundary behavior, yet maintain high computational efficiency and simplify pre-processing.
Commands
framesuite
    frame_type                               TEMPORAL
    frame_obj_phase                          2
    frame_fluid_phase                        1
    frame_road_phase                         3
    frame_road_profile_file_name             road_profile.txt
    frame_road_path_file_name                road_path.txt
    frame_road_clip_zcoord                   -0.4
    frame_fluid_clip_zcoord                  -0.6
    frame_min_bc_overlay                     "3 0 0"
    frame_max_bc_overlay                     "3 0 0"
    frame_freeze_layer_length                0.05
    frame_sponge_layer_length                0.05
    frame_freezesponge_min_bc_clip           "1 1"
    frame_freezesponge_max_bc_clip           "1 1"
    frame_freezesponge_min_bc_clip_zcoord    "-0.6 -0.6"
    frame_freezesponge_max_bc_clip_zcoord    "-0.6 -0.6"
| Command | Contents | SI Unit Example |
| frame_type | Type of frame that is applied Options
 Default = No default  |
| frame_obj_phase | The phase of interest that is followed by the frame (car body). Note:
| frame_fluid_phase | Fluid phase ID (water) which is spawned as the frame
                                    moves. Note: Selected phase must be a FLUID phase type for both
                                    SLIDING and TEMPORAL frame types.
| frame_road_phase | Road phase ID (road) which is spawned as the frame moves. Note:
| frame_road_profile_file_name | Absolute or relative path to the file containing road top profile
                                in the YZ plane. The file consists of two columns, Y and Z, where
                                the Y coordinates are strictly increasing. Note: This command is
                                    relevant for both SLIDING and TEMPORAL frame
                                types.
| frame_road_path_file_name | Absolute or relative path to the file containing road path in the
                                XZ plane. This file consists of two columns, X and Z, where the X
                                coordinates are strictly increasing. Note: This command is only
                                    relevant for the SLIDING frame type selection. In case of
                                    TEMPORAL frame it is ignored.
| frame_road_clip_zcoord | Absolute Z coordinate above which the spawned road particles are
                                    removed. Default = 0.0  |
                            [m] |
| frame_fluid_clip_zcoord | Absolute Z coordinate below which the fluid spawns. Fluid depth
                                in Z direction is the difference between
                                    frame_fluid_clip_zcoord and minimum Z value
                                in frame_road_path_file_name file. Default = 0.0  |
                            [m] |
| frame_min_bc_overlay | The layout of additional internal layers at the frame domain
                                boundaries lying on the minimum planes in the X, Y and Z
                                    directions. Options
 Note: This command is a vector representing the minimum
                                    X, Y and Z boundaries. For example "0 0 0" implies that no
                                    layers are applied on any of the minimum domain
                                    boundaries.
Default = 0 0 0  |
| frame_max_bc_overlay | The layout of additional internal layers at the frame domain
                                boundaries lying on the maximum planes in the X, Y and Z
                                    directions. Options
 Note: The command is a vector representing the maximum X, Y
                                    and Z boundaries. For example "0 0 0" implies that no layers are
                                    applied on any of the maximum domain boundaries.
Default = 0 0 0  |
| frame_freeze_layer_length | Absolute length of the freeze layer, in a direction perpendicular
                                to the relevant bounding plane pointing toward the computational
                                    domain. Note: This command has no effect:
 Default = 0.0  |
                            [m] |
| frame_sponge_layer_length | Absolute length of the freeze layer, in a direction perpendicular
 Default = 0.0  |
                            [m] |
| frame_freezesponge_min_bc_clip | Freeze and sponge layer clip height selection mode in Z direction
                                for X = C and Y = C minimum bounding planes, respectively. This
                                command has a two-value vector of the form "0 0". Options
 Default = 0.0  |
| frame_freezesponge_max_bc_clip | Freeze and sponge layer clip height selection mode in Z direction
                                for X = C and Y = C maximum bounding planes, respectively. This
 Default = 0.0  |
| frame_freezesponge_min_bc_clip_zcoord | The absolute Z coordinate in X = C and Y = C minimum bounding
                                planes, respectively, above which freeze and sponge layers are
                                    applied. Important: Only active when the relevant
                                        frame_freezesponge_min_bc_clip is set to
                                    2.
Default = 0.0 0.0  |
                            [m] |
| frame_freezesponge_max_bc_clip_zcoord | The absolute Z coordinate in X = C and Y = C maximum bounding
                                planes, respectively, below which freeze and sponge layers are
                                        frame_freezesponge_max_bc_clip is set to
                                    2.
Default = 0.0 0.0  |
                            [m] |
