Plackett Burman (PB)
Screens the maximum number of main effects with the least number of experimental runs in case of two-level factors.
| X1 | X2 | X3 | X4 | X5 | X6 | X7 | X8 | X9 | X10 | X11 | |
| 1 | +1 | +1 | +1 | +1 | +1 | +1 | +1 | +1 | +1 | +1 | +1 |
| 2 | -1 | +1 | -1 | +1 | +1 | +1 | -1 | -1 | -1 | +1 | -1 |
| 3 | -1 | -1 | +1 | -1 | +1 | +1 | +1 | -1 | -1 | -1 | +1 |
| 4 | +1 | -1 | -1 | +1 | -1 | +1 | +1 | +1 | -1 | -1 | -1 |
| 5 | -1 | +1 | -1 | -1 | +1 | -1 | +1 | +1 | +1 | -1 | -1 |
| 6 | -1 | -1 | +1 | -1 | -1 | +1 | -1 | +1 | +1 | +1 | -1 |
| 7 | -1 | -1 | -1 | +1 | -1 | -1 | +1 | -1 | +1 | +1 | +1 |
| 8 | +1 | -1 | -1 | -1 | +1 | -1 | -1 | +1 | -1 | +1 | +1 |
| 9 | +1 | +1 | -1 | -1 | -1 | +1 | -1 | -1 | +1 | -1 | +1 |
| 10 | +1 | +1 | +1 | -1 | -1 | -1 | +1 | -1 | -1 | +1 | -1 |
| 11 | -1 | +1 | +1 | +1 | -1 | -1 | -1 | +1 | -1 | -1 | +1 |
| 12 | +1 | -1 | +1 | +1 | +1 | -1 | -1 | -1 | +1 | -1 | -1 |
Usability Characteristics
- Only 2-level variables can be used.
- The Number of runs is a factor of four.
- The maximum number of variables you can use is 35.
- Best suited for problems where the interactions are expected to be minimal and the main effects dominate.
- Any data in the inclusion matrix is combined with the run data for post-processing. Any run matrix point which is already part of the inclusion data will not be rerun.
Settings
| Parameter | Default | Range | Description |
| Design | Auto Select |
 Note: pbdgn stands for Plackett Burman
                                        design. | Select the lowest number of runs sufficient to study effects. |
| Resolution | III | III | Select the resolution. |
| Number of Runs | Dependant upon design selected. | 8-36 | Number of new designs to be evaluated. |
| Use Inclusion Matrix | Off | Off or On | Concatenation without duplication between the inclusion and the generated run matrix. |
