Load your own design matrix.
            The run matrix is read by
HyperStudy and used like any other design.
                Spaces, tabs, or commas can delimit the individual elements of the matrix. The rows
                define the different runs and the columns define the input variable values.
Table 1. Example: Run Matrix
                                | 1.0 | 2.0 | 3.0 | 4.0 |
                                | 4.1 | 4.3 | 4.5 | 4.6 |
                                | 6.7 | 8.1 | 10.0 | 11.0 |
                                | 17.2 | 1.0 | 1.0 | 3.0 |
                                | .02 | 0.4 | 0.5 | 1.7 |
                                | 3.4 | 2.1 | 7.3 | 9.1 |
Usability Characteristics
                    - Create your own design based on individual requirements.
- The matrix does not have to fit any DOE type
                        requirements. You can use it to automate a parameter study.
- The run matrix uses exact values of the variable. This is in contrast to the
                        user defined DOE, which contains integers to
                        represent the corresponding level of the variable.
- It is not necessary to utilize all designs in a study. Designs that are not
                        desired can be turned off from the Write/Execute runs panel.
- Imported values are mapped to the independent variables.
- Any data in the inclusion matrix is combined with the run data for
                        post-processing. Any run matrix point which is already part of the inclusion
                        data will not be rerun.
        Settings
            In the Specifications step, Settings tab, change method
                    settings.
                                | Parameter | Default | Range | Description |
                                | Matrix File |  |  | File that has the dataset for your own design of
                                    matrix. |
                                | Use Inclusion
                        Matrix | Off | Off or On | Concatenation without
                            duplication between the inclusion and the generated run matrix. |
