Sequential Quadratic Programming (SQP)
A gradient-based iterative optimization method and is considered to be the best method for nonlinear problems by some theoreticians. In HyperStudy, Sequential Quadratic Programming has been further developed to suit engineering problems.
Usability Characteristics
- A gradient-based method, therefore it will most likely find the local optima.
- One iteration of Sequential Quadratic Programming will require a number of simulations. The number of simulations required is a function of the number of input variables since finite difference method is used for gradient evaluation. As a result, it may be an expensive method for applications with a large number of input variables.
- Sequential Quadratic Programming terminates if one of the conditions below are
                        met:- One of the two convergence criteria is satisfied.- Termination Criteria is based on the Karush-Kuhn-Tucker Conditions.
- Input variable convergence
- The maximum number of allowable iterations (Maximum Iterations) is reached.
- An analysis fails and the Terminate optimization option is the default (On Failed Evaluation).
- The number of evaluations in each iteration is automatically set and varies due to the finite difference calculations used in the sensitivity calculation. The number of evaluations in each iteration is dependent of the number of variables and the Sensitivity setting. The evaluations required for the finite difference are executed in parallel. The evaluations required for the line search are executed sequentially.
Figure 1. Sequential Quadratic Programming Process Phases
Settings
| Parameter | Default | Range | Description |
| Maximum Iterations | 25 | > 0 | Maximum number of iterations allowed. |
| Design Variable Convergence | 0.0 | >=0.0 | Input variable convergence parameter. Design has converged when
                            there are two consecutive designs for which the change in each input
                            variable is less than both (1) Design Variable
                                Convergence times the difference between its bounds, and (2)
                                Design Variable
                                Convergence times the absolute value of its initial value
                            (simply Design
                                Variable Convergence if its initial value is zero). There also
                            must not be any constraint whose allowable violation is exceeded in the
                            last design. Note: A larger value allows for faster convergence, but
                                worse results could be achieved. |
| On Failed Evaluation | Terminate optimization |
| Termination Criteria | 1.0e-4 | >0.0 | Defines the termination criterion, relates to satisfaction of
                                    Kuhn-Tucker condition of optimality. Recommended range: 1.0E-3 to 1.0E-10. In general, smaller values result in higher solution precision, but more computational effort is needed. For the nonlinear optimization
                                            problem: Sequential Quadratic Programming is
                                        converged if: |
| Sensitivity | Forward FD |
 | Defines the way
                                        the derivatives of output responses with respect to input
                                        variables are calculated.
 Tip: For higher solution precision, 2 or 3
                                            can be used, but more computational effort is
                                            consumed. |
| Max Failed Evaluations | 20,000 | >=0 | When On Failed Evaluations is set to Ignore failed evaluations (1), the optimizer will tolerate failures until this threshold for Max Failed Evaluations. This option is intended to allow the optimizer to stop after an excessive amount of failures. |
| Use Perturbation size | No | No or Yes | Enables the use of Perturbation Size, otherwise an internal automatic perturbation size is set. |
| Perturbation Size | 0.0001 | > 0.0 | Defines the size of the finite difference perturbation. For a variable x, with upper
                            and lower bounds (xu and xl, respectively), the following logic is used
                            to preserve reasonable perturbation sizes across a range of variables
                                magnitudes:
| Use Inclusion Matrix | With Initial |
