An output response is a measurement of system performances, such as weight, volume,
        displacement, stress, strain, reaction forces, and frequency.
            Create and define the output responses that will be used in the studies DOE, Fit,
                Optimization, and Stochastic approaches.
            Output responses may be defined using a combination of results read or extracted from
                a file and input variable values. These equations may use the functions available or
                external functions, including
Compose/OML and Python functions.
HyperStudy uses
HyperWorks readers and hence can read the binary output files of most popular CAE solvers.
                Additional data can be read using custom external readers and import templates.
