Define Goals (Objectives/Constraints)
Goals are used to define objectives and constraints.
                Define goals for the active output response.
                - Go to the Define Output Responses step.
- Click the Define Output Responses tab.
                        In the Goals column, click  .
                        A dialog opens. .
                        A dialog opens.
- In the Type column, select the type of goal to create.
- In columns 1 and 2, define additional options as needed.
- Click OK.
                Define goals manually.
- Click the Objectives/Constraints - Goals tab.
- Click Add Goal.
- In the Apply On column, select the output response to which this goal will be applied.
