Register Solver Scripts
You need to register solver scripts when the solver is not a suite solver and hence is not registered by default, or when you need to perform a series of actions such as copying files, running one or more solvers, and extracting data.
Register Solver Scripts in HyperStudy
Register solver scripts in HyperStudy with the Register Solver Scripts dialog.
                Open the Register Solver Script dialog.
                - From the menu bar, click .
- In the Define Models step, click the Solver Execution Script cell and select Register new Solver from the drop-down menu.
                Add a solver script.
- In the Path column, enter the location of the solver script to be registered.
- Optional: In the Arguments column, enter a solver script argument for the solver script.
- Click Close to exit the solver registration.
Register Solver Scripts by Editing the Preferences File
Register solver scripts in the *BeginSolverDefaults section of the preferences_study.mvw file.
Example: Register LS-DYNA in the Preferences File
*BeginSolverDefaults()
*RegisterSolverScript(radioss,"RADIOSS",{ getenv("radioss_launch") }, HST_SolverRadioss)
*RegisterSolverScript(os,"OptiStruct",{ getenv("opti_launch") },    HST_SolverOptiStruct)
*RegisterSolverScript(templex,"Templex",{getenv("templex_launch") }, HST_SolverGeneric)
*RegisterSolverScript(hx,"HyperXtrude",{getenv("hx_launch") },      HST_SolverGeneric)
*RegisterSolverScript(ms,"MotionSolve - standalone", { getenv("ms_launch") }, HST_SolverMotionSolve)
*RegisterSolverScript(tcl,"TCL",{ getenv("tclsh_fullpath") }, HST_SolverGeneric)
*RegisterSolverScript(lsdyna, "Ls-Dyna", "C:\Solvers\dyna\dyna.exe", "HST_SolverGeneric")
*EndSolverDefaults()
