rpti::item has
Check if an item attribute, property or role exists.
rpti::item hasattribute
Check if an item attribute exists.
- Syntax
- rpti::item hasattribute
- Parameters
                        - -id
- Value: Item ID.
 - -name
- Value: Attribute name.
- Returns
- 1 if role exists, 0 if role does not exist.
rpti::item hasProperty
Check if the item has property with specified key.
- Syntax
- rpti::item hasProperty
- Parameters
                        - -id
- Value: Item ID.
 - -key
- Value: Property key.
- Returns
- 1 if valid, 0 if invalid.
rpti::item hasrole
Check if an item role exists.
- Syntax
- rpti::item hasrole
- Parameters
                        - -id
- Value: Item ID.
 - -name
- Value: Role name.
- Returns
