rpti::item remove
Remove an item from parent.
- Syntax
- rpti::item remove
- Parameters
                        - -id
- Value: Item ID. Item ID to remove.
- Returns
- 1 if success, error message if failed.
rpti::item removerole
Remove item role if exists.
- Syntax
- rpti::item removerole
- Parameters
                        - -id
- Value: Item ID.
 - -name
- Value: Role name
