rpti::item::slide
Interact with items of type slide. This item type is valid only for presentation reports.
- Supported Property Names
- -name -value -parent -type(read only) -layoutname or -index -layoutnameNote:- -layoutname: name of the layout.
- The slideindex starts from 1
rpti::item::slide create
Creates an item of type "slide".
- Syntax
- rpti::item::slide create
- Parameters
                        - For
- Value: A full list of standard property names see Supported property name above.
- Returns
- The ID of the item or .tcl-error in case an error occurred during creation.
- Example
- rpti::item::slide create -name "My Slide Item"
rpti::item::slide delete
Deletes the item with the specified ID.
- Syntax
- rpti::item::slide delete
- Parameters
                        - -id
- Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
 - For
                                    property name above. Use rpti::item getpropertykeylistfor list of dynamic properties.
- Returns
- 1 for OK, .tcl-error in case of error.
- Example
- rpti::item::slide delete -id $id
rpti::item::slide get
Queries the value of one property.
- Syntax
- rpti::item::slide get
- Parameters
                        - -id
 - For
- Returns
- The value of the specified property or .tcl-error in case of error.
- Example
- rpti::item::slide get -id $id -property parent
rpti::item::slide getpropertyid
Queries ID of property.
- Syntax
- rpti::item::slide getpropertyid
- Parameters
                        - -id
 - -key
- Value: Property key.
rpti::item::slide getpropertykeylist
Queries list of properties.
- Syntax
- rpti::item::slide getpropertykeylist
- Parameters
                        - -id
rpti::item::slide set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
- Syntax
- rpti::item::slide set
- Parameters
                        - -id
 - For
- Returns
- Example
- rpti::item::slide set -id $id -name "My Slide Item" -value "Good monring, how are you today?"
