rpti::item::module
Create or modify report modules.
rpti::item::module create
- Syntax
- rpti::item::module create
- Example
- rpti::item::module create -config "HwLoop"
- Supported Property Names
- To set loop results properties, use the following:
                        - name
- Name- Value
- String
                        - hw_page Model
- Model- Value
- Page 1/Window 2
- Page window source
                        - comp_ids
- Components- Value
- list of component ids
                        - group_ids
- Sets- Value
- list of set ids
                        - add_displayed
- Add displayed components
                        - lcase_options
- Load Cases- Value
- Active, Last and Multiple
                        - lcase_datalist
- Selected Load Cases- Value
- {simulationid subcasid}
- {1 0}
                        - exclude_hide_etype
- Entity Type- Value
- Sets and Components
- Entity type for exclude and hide option
                        - mask_set_ids
- Enity Selection (Set)- Value
- Set Ids
                        - mask_comp_ids
- Enity Selection (Components)- Value
- Component Ids
                        - exclude_etype
                        - ignore_element_set_ids
- Entity Selection(Set)- Value
- Set Ids
                        - ignore_component_ids
- Entity Selection(Component)- Value
- Component Ids
                        - ignore_num_layers
- Number of Layers- Value
- Integer
                        - loop_start
- Start loop with- Value
- Component and loadcase
                        - add_complete_overview
- Overview for each loadcase- Value
- 0 or 1
- Enable overview for each loadcase
                        - exportopt
- Export- Value
- All, Above, Below, EqualTo and Overview
                        - expcriteria
- Export- Value
- real number
- Export Criteria Value
                        - loop_over_hotspots
- Loop Over Hotsport- Value
- 0 or 1
- Enable loop over hot spots
                        - create_table.
- Create results review table in the loop output. This is on by default.- Value
- 0 or 1.
- Example
- ::ardi::item set -id $loopitemid -create_table 1
- split_table
- Auto Split Table- Value
- 0 or 1
                        - split_table_type
- Split table by columns or rows- Value
- Columns or Rows
- Auto split table by row or column
                        - split_rows
- Maximum Rows- Value
- Integer
                        - split_cols
- Maximum Columns - Value
- Integer
