mdlIModelClient GetMdlFileStatsList
Gets the details a file.
mdlIModelClient_Handle GetMdlFileStatsList filename, return_list
MotionView Tcl Query
This command retrieves the details of a file.
- filename
- The full path of the file for which details are to be retrieved.
- return_list
- This is a boolean argument. - True
- The file stats will be returned as a list.
- False
- The file stats will be returned as a name value map (a typical set of stats represented in the name value map is shown below):
 FileType=ROOT BeginModelKeyExists=true EndModelKeyExists=true WizardSelectionsExist=false StandardInclude=FILE NumSystemDefinitions=0 NumAssemblySelections=0 NumAnalysisSelections=0
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
set temp [mcl GetMdlFileStatsList slider_crank.mdl]
if {[lindex $temp 3] == "WizardSelectionsExists=false" } {
   puts "File does not contain wizard selections"
} else {
   puts "File contains wizard selections"
if {[lindex $temp 7] == "false" } {
} else {
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;Errors
Returns the file stats if successful. If there is an error, an error code will be returned.
