mdlIModelClient SuppressMessages
Suppresses messages into the Message Log.
mdlIModelClient_Handle SuppressMessages suppress
MotionView Tcl Modify
This command suppresses messages into the Message Log.
- suppress
- Valid values are: - True
- False
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SuppressMessages true
sess1 ReleaseHandle;
hwi CloseStack;Errors
Returns 0 if successful.
