mdlIModelClient SetSaveOption
Sets the value of the option specified for saving a model.
mdlIModelClient_Handle SetSaveOption option, value
MotionView Tcl Modify
This command sets the value of the option specified for saving a model.
- option
- Valid arguments are: - data
- include
- Write_solvermode
- topology
- value
- The value is True or False for all arguments except topology (for which the value is MDL).
set temp 0
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SetSaveOption data true;
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;Errors
Returns 0 if successful.
