mdlIModelClient PostMessageToLog
Displays text in the message log.
mdlIModelClient_Handle PostMessageToLog text, type
MotionView Tcl Modify
This command displays text in the message log.
- text
- The message to be posted to the log.
- type
- Message type:- 0
- Warning
- 1
- Error
- 2
- Message
- 3
- No Message type
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl PostMessageToLog "This is a test" 2
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;Errors
None.
