poIAdvancedQuery GetNumericPrecision
Gets the numeric precision from the advanced query.
advancedQuery_handle GetNumericPrecision
HyperView Tcl Query
This command is used to get the numeric precision from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle SetNumericPrecision "5"
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query handle does not exist anymore.
