poIAdvancedQuery GetSubcaseList
Gets the subcase list applicable for the advanced query.
advancedQuery_handle GetSubcaseList
HyperView Tcl Query
This command is used to get the list of subcases which are applicable for the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query handle does not exist anymore.
