poIAdvancedQuery GetValueList
Gets the values from the advanced query.
advancedQuery_handle GetValueList
HyperView Tcl Query
This command is used to get the values from the advanced query and the output is written into the Tcl command prompt.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query handle does not exist anymore.
